After each update of Fusion, Windows 10 hangs at next Hibernate
This problem is back as of the last two Fusion updates: after the update is done and Fusion has restarted, all seems fine, but if I shut down Fusion and later try and hibernate my desktop PC (windows 10 latest version), the PC hangs partway through the hibernate shutdown. Screen goes black, but none of the devices including fans/keyboard turn off, and the power switch will not wake it back up again. Only way to wake the PC is to hold in the power button to hard boot it again.
This was a problem all of last year but went away several months ago. I and others have posted bugs about this numerous times, never any fix from Autodesk. Some have suggested using Sleep instead, that didn't help. Also was discussion about letting the Streamer.exe from Autodesk's folder finish, which takes 5 or 10 minutes after the update. That does not help either.
Anyone on the Fusion team ever look into this?? As a paid subscriber seems like SOME response is warranted.
