I have a rectangle with a smaller cylinder going through it, both are bodies I want to keep. I cut the cylinder out of the rectangle and how have a cylinder shaped hole in the rectangle, but when I go to PressPull the cylinder in the rectangle (because I want it to be slightly larger than the original cylinder) it seems to be linked to the cylinder and changes the cylinder size as well. I only want the rectangle to change though. How do I unlink them?
Edit: I tried with a straight rectangle and cylinder and it worked. In actuality it's an imported object being subtracted from a parametric object with design history turned on. Once I've subtracted, if I try to PressPull the wall of the empty space, it acts weird. f3d attached
