Admin privileges to open Fusion 360
Message 1 of 8
I installed Fusion 360 for education on school lab desktops. When students want to open this software a pop-up to ask for administrator privileges appears. Students don't have this.
Right click "run as administrator" or UAC off is not a solution.
What can I do to solve this problem?
Replies (7)
Message 2 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
Did you run a lab install?
If not, you'll need to follow these steps to have all users be able to run Fusion, not just the admin.
https://www.autodesk.com/education/free-software/fusion-360-for-educational-institutions?_ga=2.12124...
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Message 3 of 8
The YouTube-link in the knowledge database does not work, but I will try the installation anyway.
link not availablelink not available
Message 4 of 8
I followed every step to install  fusion in lab environment.
When installed, Fusion want launch unless I use right click "run as administrator". This works with an adminaccount, but not with a student account.
So I also looked for the solutions on https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/Fusio...
- stopped virusscanner
- allowed fusion through firewall
- no proxy is used, so no troubles here
- I ensured that all users have all privileges on "C:\Program Files\Autodesk" and all submaps.
The problem still isn't solved. I tried everything and am now a bit desperate.
Message 5 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
Those are all good troubleshooting steps. Are you sure you installed the correct version of Fusion? There are two versions - one is for personal use so would require admin use, and there is the lab version that should allow student access.
I also found this article which looks more like the process I went through to setup my lab when I worked in a school.
Did you run the .exe from the command line? I would read through this page and decide which one is best for you. I used the all-users self contained, but the drawback on that one is that you have to manually update each seat. The web-sourced might be better, but it notes that it uses a higher amount of network traffic at times.
Let me know how it goes.
Message 6 of 8
Hi Karina
Yes, I used command line to install.
Tomorrow I continue troubleshooting to find a solution.
Geert
Message 7 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
Let me know how it goes. I recommend uninstalling and trying again using the instructions I linked. Also, you might install from a student account and not the admin account (entering the password as needed).
Message 8 of 8
ddehaan
I'd ran into the same problem, but used process monitor to find out where it went wrong.
In my case there was an "Access Denied" on the folder: c:\ProgramData\Autodesk.
When i gave the group Users write and change rights, the program started.
Kind regards,
Dennis de Haan
