I posted ""Additive Travel Speed" on the Manufacture forum but it has had no attention for some time. I think that this is a bug--basically the Travel Speed, which should be about 200mm/sec as the 3D print head moves to new locations, is nowhere near that. It is in fact very slow--about 3mm/sec. (vs 200). Check the above post for some details.
I think this was brought up once before but it does not seem that it was every solved. I placed my STL file in CURA and I get the results one would expect--the travel is very fast. At present, using Fusion, this problem can add an hour to a 3 hour print. It seems that travel speed is not being properly entered into the GCODE files, perhaps something with UNITS?
Fritz
