Additive Suggestion - Park after printing location
I noticed there's now a "park" position for when the print completes. However, I really, really don't want to waste all the movement to push my Z axis to the top, and the print bed moves in the completely wrong direction to present the part for removal.
I would love options to set something a bit better than this. A suggestion to improve the final park position after a print:
X-Y, move to a certain coordinate. (Allow setting individually, or as a pair.)
Example: When done printing, move the X and Y axes to their home position (0,0). Or... in my case, with an Ender 3, I just want the Y axis to move to 235mm, which presents the part nicely in front of the printer. I honestly don't care if the X axis moves to its home position or not. If we could enable only one axis for a park position, that would be great, but I'll happily set both if it must be that or nothing. Otherwise, I keep having to modify my final g-code section to go to y=235mm.
The Z axis I'd love to adjust separately. Either let me set an absolute value (if I really feel like measuring, or pushing Z to its max height), or present an option to move a certain distance above the last/highest Z position in the toolpath by a certain amount.
Example: My print's final layer ends at 50mm in height. When the print finishes, bump the height by 10mm to a total of 60mm, then present the print using the X-Y park position mentioned above. If the print finishes with less than 10mm left in its maximum Z-axis position, just move to the top (defined in the print volume for the machine).
