[Additive] Severe under-extrusion with larger nozzles
I have a Creality Ender 3 printer that I've modified a bit, swapping out the hot end and extruder to a Slice Engineering Mosquito and Bondtech BMG-M geared direct extruder. I've been utilizing Fusion 360 for my 3D printing needs for some time. I have run into an odd issue that I can't really explain away.
I've been tinkering with nozzle sizes other than 0.4mm. I've noticed I need to compensate for changes in flow rate. As nozzle sizes get larger or smaller, most of my flow rates have been somewhat predictable. For PLA, larger nozzles require lower flow rates to get proper wall thicknesses. But, not with PETG and a 0.8mm nozzle size. I'm getting severe under-extrusion and need massive flow rates to get solid lines down on the bed.
However, the fact that I have flow rates for PLA ranging from 95.7% with 0.4mm nozzles to 81.4% with 0.8mm nozzles tells me there's something off about how Fusion 360 is calculating the volume or linear distance that should exit the extruder. I've gotten comments elsewhere that flow rates should hover around 100% within a few percent, if settings are otherwise good.
Things I've verified are set properly:
- Basic > Extrusion Width > 0.8mm
- Extruder > Filament Diameter > 1.75mm
- Layer > Perimeter Extrusion Width > 0.8mm
- Layer > Layer 1 Extrusion Width > 0.8mm
- Infill > Infill Extrusion Width > 0.8mm
- Skirt-brim > Prime Extrusion Width > 2.0mm
- Bridging > Bridge Extrusion Width > 0.9mm
- Brim, Raft, and Support are unused. I do print a skirt with 2 passes, 1 layer.
So... why are my flow rates so varied? What's happening behind the scenes that could cause this issue? Why am I needing to crank up my flow rate with a 0.8mm nozzle to 160% just to get solid lines to lay down on the bed? Is this a bug in Fusion 360 or the Creality post-processor?
Smaller nozzles seem to print just fine, though again, I do need to adjust flow rates a noticeable amount to achieve good prints.
