Message 1 of 1
Adding then deleting a line from a fully constrained sketch makes it unconstrained.
Hey!
I've had this problem with a number of sketches:
- The sketch has a number of offset curves.
- The sketch is fully constrained.
- If I then draw a line between 2 of the offset curves, and delete the line again, all the offset curve become unconstrained.
- This only seems to happen to sketches that reach a certain level of complexity. It doesn't happen if I make a new sketch, create a couple offset curves and try and re-create the problem.
I've attached 3 files.
- State 1. Fully constrained.
- State 2. Added line between 2 offset curves.
- State 3. Deleted the line. Sketch now unconstrained.
Note of offset curves:
- I originally was using the Offset Curve feature, and had this problem.
- This time, I just manually re-drew the curves, made the corner radii concentric, and offset the curves manually. Same problem.
Any ideas? It makes it tough that I can't backtrack into a sketch a delete lines I no longer need.
