Adding a font while using Fusion 360 online
krauserHMCNY
krauserHMCNY
My students are using the online version of Fusion 360. They would like to add a font but have not been able to do so. Can someone guide us as to how to add a font while using Fusion 360 online?
HughesTooling
Pretty sure this can't be done and even if you managed to install a new font on the virtual PC, the next time you used Fusion the font would not be there so Fusion would use Arial as the default.
Your only workaround is use another program to create an SVG file you can upload to your hub and insert into your designs.
Mark
Mark Hughes
Owner, Hughes Tooling
krauserHMCNY
Thank you, I’ll try that workaround.
HughesTooling
Note you will need to trace the edges (convert to path) of the text in your graphics program before exporting.
Mark
Mark Hughes
