Announcements
add title block to existing sketch
wwfeldman
wwfeldman
i have a sketch
i want to add a title block and border
i opened a drawing with an ISO template, but could not copy sketch into the drawing
so:
what's the difference between a sketch and a drawing?
how do i add a drawing template, such as the ISO template, to a sketch?
alternatively, how do i copy my sketch into a drawing?
jhackney1972
You can follow the video.  As emphasized in the video, the plan you sketched the entities on must be chosen as the view in the 2D Drawing.
Edit: If you want to add a Title Block to a Drawing, especially if creating a template, this Blog Article and Video may be of help to you.
John Hackney, Retired
wwfeldman
it worked
thank you
i got the dimensions also, (auto dimension) but it dropped trailing 0
and when i made them 3 decimal places, some stayed 1 decimal place,
or two decimal places, and some made the third decimal place a 3 instead of a zero
how may i bring in the dimensions from the sketch?
(instead of auto-dimension)
what is the difference between a sketch and a drawing?
apparently F360 sees them as different things, but i do not
g-andresen
1. A sketch is required in order to create a body from it using the body tools Extrusion, Sweep... to create a body.
A drawing is derived from this body, in which multiple views can be created.
2. In drawing mode, you can use various dimensioning tools.
günther
wwfeldman
i built the sketch with dimensions
why do they not carry over to the drawing?
why did the dimensioning tools in the drawing not match the dimension i assigned in the sketch?
