Add GPU capabilities / option to boost performance
jeffdbeats
jeffdbeats
Please add GPU capabilities / ability to use GPU to boost the speed of Fusion. I have read it is CPU based, I am using the I9-9900K + 32gb ram and even still it will sometimes freeze with even simple drawings. The RTX-3090 is coming out this month, and it would be great to be able to leverage its power inside Fusion360 for faster performance.
Edit: found the issue why it was slow... I was using .dxf import... (still would be good to have GPU support though)
My solution was to extrude the dxf. and then reproject in in Fusion.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
g-andresen
My recommendation:
Just pay a little attention to what you import and you will have no problem in Fusion.
Inadequacies in imported sketches cannot be compensated by an optimized graphics system.
günther
jeffdbeats
I am making a feature request, I would like to see GPU support for fusion, so I can leverage the power of the upcoming GPU's. It has nothing to do with inadequacies, I just happened to get the idea while Fusion360 was slow because its not good at importing DXF files. Having the ability to use more powerful hardware is what I am suggesting. I could have an amazing GPU, but that doesn't matter because Fusion is not yet leveraging its power.
mullcom
Hi everyone 👋
I also want use more of my hardware to boost fusion360. It's like buy a tesla but you only allows to use 20% of the battery or power of the electric engine..
