Fusion Support
AD to drop support for Fusion on Windows 10 in less than 6 months time
1 REPLY 1
jz79
153 Views, 1 Reply
I would really like an explanation as to why AD has decided to do this, since W10 is supported by MS till 2025 at least?
edit: never mind, didn't read it attentively enough, support is dropped for 1803 version and older of W10
1 REPLY 1
jhackney1972
in reply to: jz79
If you have not updated your Windows 10 OS since April 2018, which was when version 1803 was released, you are really behind the times.  This is the Windows 10 version that will not be supported after March 2023 as noted in the Fusion 360 system requirements shown below.
I am posting this even though you have realized your posting error so others will be able to understand the dates better.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
