Announcements
acis error, infinite something
elephantwalker
elephantwalker
See the error in the screen capture here.
 See the f3d file below to reproduce this error. I found that this is an error message by ACIS, very esoteric. Infinity is an idea, not a number.
From the ACIS appendix documentation this error is :
 NO_OUTSIDE_SHELL . . . . . . . . . . . . . . . . . . . . . eulr/euler/kerndata/seplumps/seplumps.msg
“infinite body – no bounding shell found”
Any ideas?
-Lawrence
TheCADWhisperer
@elephantwalker wrote:
Any ideas?
@elephantwalker
If I go back to the beginning and check the imported body before any actions were done - Fusion reports 58 invalid surfaces.
If I attempt to Repair...
elephantwalker
I want to thank you for pointing me in the right direction. The problem is indeed the openVSP export. I experimented with options for export, and found the reducing the step tolerance to 0.001 reduces the number of bad patches to 12. By going through a series of repair and stitch cycles, I was able to get a working body. The key bit was at one cross section at 25 mm or so, this could not be repaired. So I took a small patch between the bodies near 25 mm, and used the point along a path to get consistent linear rails between the faces, and was able to loft the bodies together.
Why would I do all of this work, instead of designing the wing in fusion 360? The original design is from the prototype for the Mars wing mission. I wanted to make a toy rc wing that was close to the prototype, less than 250 g, that could be easily 3d printed. I am using Tom Staton's wing design/print method.
Your help in pointing to the validate tool was the key bit that took me across the finish line. Thanks Man!
-Lawrence
