Announcements
Absent option depth in such Rib & Web e.t.c. tools.
serzh82saratov
serzh82saratov
Active Plan: Fusion 360, Personal
Windows 10 Pro 20H2 x86_64 (19042.1586)
g-andresen
Please share the file and explain, what you want to achieve.
File > export > save as f3d on local drive  > attach it to the next post.
günther
jeff_strater
You only get a "Depth" input if you select "Distance" as the Extent Type:
In your image, you have the type set to "To Next", which does not need or allow a "Depth" parameter
Jeff Strater
Engineering Director
serzh82saratov
Thanks for help!
