About the new 10 active document thing
how will it exactly work? cause wording isn't really clear, if it's for example:
10 active components, you can only edit 10 of those at one time without having to close them and select the new ones, but you can still use them in bigger assemblies just like before without having a referenced parts limit (for example a big complex assembly with 20-30 components)
that wouldn't be a problem at all, when you rarely need to edit a component you just do it, but can you still use a ton of referenced individual components in an assembly? it's super important for my hobby use, building things like a better extruder for my printer, a stiffer frame and such i frequently go above 15 referenced components from my own library
