Fusion Support
50mm turns out to be 5mm, help
2 REPLIES 2
benkepple_
75 Views, 2 Replies
every unit of messurement i input isnt scaled correctly, say i want a length of 50mm, fusion displays this as 50.0mm which is fine BUT When i export the obj. file to bambu studio it turns out to only be 5mm in lengh. I cant find a way to fix, adjust this.
2 REPLIES 2
jeff_strater
in reply to: benkepple_
OBJ format is unitless, so you will need to tell Bambu that the units are MM on import.
is OBJ unitless?
Jeff Strater
Engineering Director
benkepple_
in reply to: jeff_strater
i didnt know this was the case, thanks for the response and your help.
