50mm turns out to be 5mm, help
benkepple_
Observer Observer
benkepple_
Observer
Observer
every unit of messurement i input isnt scaled correctly, say i want a length of 50mm, fusion displays this as 50.0mm which is fine BUT When i export the obj. file to bambu studio it turns out to only be 5mm in lengh. I cant find a way to fix, adjust this.
jeff_strater
OBJ format is unitless, so you will need to tell Bambu that the units are MM on import.
is OBJ unitless?
Jeff Strater
Engineering Director
benkepple_
Observer
Observer
i didnt know this was the case, thanks for the response and your help.
