Fusion Support
5/16" Hole doesn't work anymore...
8 REPLIES 8
Message 1 of 9
azurgrip
239 Views, 8 Replies
As of the most recent Fusion update, the HOLE command has developed a bug.
I can't create a hole that's 5/16", counter bored, clearanced, full depth of material. I get a modelling error (See screenshot). However it all works fine if I create a 1/4" or 3/8" hole with the dame specs.
Any suggestions?
8 REPLIES 8
Message 2 of 9
seth.madore
in reply to: azurgrip
I did a quick test of this and it appears to be working as expected.
Would you be able to share your Fusion file here or privately?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Seth Madore
Message 3 of 9
azurgrip
Hi Seth,
Thank you for replying. There's no real file to show. It's just me starting from scratch. I have been able to create the hole desired now, (just playing in a a solid block and doing a full depth drill) however Fusion is still coming up with modelling errors. - very frustrating for me - a new user trying to interpret the  errors.
Message 4 of 9
TheCADWhisperer
@azurgrip
…however Fusion is still coming up with modelling errors. - very frustrating for me - a new user trying to interpret the  errors.
@azurgrip
Can you File>Export your *.f3d file that exhibits this behavior to your local drive and then Attach it here to a Reply?
Message 5 of 9
azurgrip
Can do. It will have to wait to next week as I'm away from home till then. Thank you
Message 6 of 9
azurgrip
I did a like quicktime video of a simple build.
Message 7 of 9
seth.madore
Would you be able to share that Fusion file here?
Seth Madore
Message 8 of 9
azurgrip
Here's the Fusion file from that clip
Message 9 of 9
azurgrip
I've just downloaded the August 8 / 23 update to F360 and it may have fixed the issue. I was able to create 5/16" holes without my previous issue. Very odd...
Anyone from Autodesk like to shed a little light?
