Hi Clint,
Thanks for responding - I have tried that and it did work - excellent!
However I did have to create the template from scratch - that was my experience. This is an area for improvement for Fusion360, to streamline the drawing tools and functionality. For new users to the software - it's not obvious, nor intuitive, that you would need to change the IN YOUR PROFILE, the settings for TEMPLATE on how to change the drawing projection standard, when really all I wanted to do was change the projection method in a newly created drawing. Different software, different workflow.
My next challenge is that I wanted to create a quick drawing that references two different views of a part at the same time - is that possible? In SW language, to show two different configurations of the part in the same drawing in side by side views. I was hoping I could reference in the same drawing, two views side by side of and object with and without holes. Unfortunately it has been anything but quick.
At first I tried two different model files using Save, then Save As to create the 2nd part. I wasn't able to see how to make this work in the drawing by looking at something equivalent to drawing view properties.
Then I tried creating for the ONE part file two different versions, and I couldn't get that to work either. Version seemed affect both drawing views, I wasn't able to seperate their display behaviour, even though they are both Base Views.
I am willing to use two different models if needed, but feel there must be an easier way.
is this possible - what is the feature that might permit this? Apparently DERIVE might be the answer, but again, my goal is to show two views side by side in the same drawing - will Derive be able to do this?
Thanks for the help
