Can somebody please explain why when drawing a 3D spline it always closes the circuit when I dont want it to???
I have tested it several times and cannot confirm your observation.
Please show your process in a screencast
günther
After each segment, you can select the next point, or the Finished, Green Tick.
Might help....
Fusion is supposed to only close the spline if you select "Close Spline Curve" from the right click menu:
I have seen occasional cases where this happens unexpectedly, but I have been unable to reproduce this reliably. If you have a repeatable recipe for doing this, we'd like to see it. Can you record a video of this behavior?
also a double click on the last point or a return ends the spline without closing it!
günther
that entry is an action, not a state. If you click OK, the spline should not close. If you right click and choose "close spline curve", it should close the spline and end the command.
