3D Parallel Toolpath Affected by WCS, Why? Is this a BUG or My Error?
I use 2D adaptive to rough a channel and leave stock on the floor and sides. I then use 3D Parallel to finish floor and sides. The tool path is correct when x-axis is in the direction of parallel tool path and "Pass Direction" is 0-degree. However, when x-axis is perpendicular to parallel tool path and I set "Pass Direction" to 90-degrees, the tool path is not complete and does not clear stock on side and floor. See attached
I also posted this same message incorrectly in the Mfg forum, but can't figure out how to edit, delete or move my post?
