Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
3D CONNEXION MOUSE NOT FUNCTIONING AFTER LATEST NOVEMBER UPDATE
emlyn.stansbie
emlyn.stansbie
I've been using the 3D Connexion space mouse for over 5 years with FUSION.
I have just updated to the latest FUSION update and there are several issues where it is not functioning as it previously did, particularly in the Manufacturing WS.
1) when trying to edit operations, if you click on an individual operation (LH side of screen), you can no longer manipulate the model with the 3D mouse. In order for you to manipulate the model again you have to click on the screen near your model.
2) In simulation mode you can't manipulate the model to move it around to interrogate your machining simulation/viewing area.
It worked fine before the update.
Any suggestions would be much appreciated?
majedationE43S5
I'm having the same issue today (18-Nov). It only zooms in and out in the design workspace when rotating the space mouse (3dconnexion); it does nothing else.
UPDATE: I've uninstalled and then reinstalled the 3dconnexion driver and the issue has been solved.
