Announcements
3D Adaptive Rest Machining Not Working
j6755
j6755
Hello, having trouble with 3D Adaptive with continue rest machining not completing path calculation when stepdown is under 1.7mm. Left it computing overnight and it stays at 80% taking 40% of cpu. If i put it over 1.7mm it works but cant run it so high. There was problems on it earlier but it got fixed. Is this related to that?
Thank you.
seth.madore
Could you share your file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
j6755
Customer part so i cant share it. Have to see if i can make a similar part and share that. But not until monday.
