3D Adaptive Clearing Corner not Machining - Small Area
mcarpenter28
mcarpenter28
Hello - Can anyone assist with understanding why this small section is not populating with a clearing line? the angle is not closed off and is actually larger than some of the other corners from an angle perspective. 1/16th end ball nose bit, with 3D adaptive clearing due to the multiple levels, however this section is flat and simply stops at the line shown.
Thank you in advance.
mcarpenter28
Close up shot of the area.
jhackney1972
Please attach your model so the forum users can use it to diagnosis your issue.  If you do not know how to attach your Fusion 360 follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
