Announcements
3 Point Plane on Mesh - not working anymore
eitanatiasd
eitanatiasd
Hey Everyone ,
Been using this method for a while. last time did that on mesh scan was a few days ago.
This morning while running fusion360 i was trying to do so again but it can not select any points on the mesh. I tried and read problems that people had in the past but nothing worked.
Even tried re-installing fusion but same issue. I can not select point on the mesh while in mesh mode trying to create a plane through 3 points.
I am running Mac OS ( yes it is updated as well ).
Thanks Ahead !
Best Regards
Eitan.
hamid.sh.
Have you tried doing in Direct Edit mode (Mesh > Modify > Direct Edit)?
Hamid
eitanatiasd
i just tried it now and it does work.
but for whatever reason no idea why it stopped working in normal mode ?
I guess i will have to do it that way , just a hassle to do it every time you need a plane. more clicks added to a simple job that was working simply before.
