2d drawing
2d drawing
richardlearl7
2d drawing
richardlearl7
Well I have a hobbiest account and I have attempted to convert my design bodies into a 2 d drawing
got the drawing and various views
however no dimensions on the drawing
I need to send this to a friend
how do I get the dimensions and how do I email the drawing to a friend?
thanks
jhackney1972
Are you saying you cannot add them using the Drawing Dimension tool?  Model sketch dimension are not brought over to the 2D Drawing in Fusion 360, at least not yet.
As far as sending the drawing to someone, you can snap a screen capture of it  or you can share a Web Database link to it via email.  Click on this link to see a 2D drawing of one of my files.
John Hackney, Retired
richardlearl7
I have tried that with no result
I will try again
jhackney1972
If you mean adding dimensions, then if they do not appear I would suspect you have a graphics issue on your system as far as Fusion 360 is concerned.  Try and change your Fusion 360 graphics driver.  If you try these settings, Fusion 360 will have to restart so save your files first.
By the way, you need to be a little more descriptive on what you are seeing, show some screen captures in your replies.
richardlearl7
good managed to get that to work this time
thanks
jhackney1972
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
