2D Drawing Bug!!
Ever since the last couple of updates I'm having a problem with the 2D drawings. I make a sheet by right clicking the part in the design area, and click create drawing. A new page opens, and I place the main view as well as side views. When I start to dimension things I'll zoom in to click points, etc. About 30% of the time when I zoom back out, or use the zoom all button, the view I was dimensioning will be broken. It will have moved slightly so the dimensions wont line up, as well as some lines of the view will be missing. The only way to fix issue is to delete the sheet and start over. This is very frustrating, especially when I spend a lot of time on a complicated drawing, only to be ruined on the last couple of dimensions.
Also, another bug that is very annoying has been happening since I started using fusion. When placing a flat pattern in a 2D drawing I normally use the leader tool to label bend lines. This works only about half the time. I'll click the leader tool, then click the bend line. Sometimes it will label the line with the angle and radius, other times it just attaches a regular leader. Once I get a regular leader there is no way I have found to fix it other than deleting the sheet and starting over--- very frustrating!!
Please fix these issues as soon as possible. I am a professional paying customer that has to use this software all day, everyday. These bugs are really slowing my work flow and ultimately costing my company money.
