After the last update I've got an error in some 2D-contour CAM operations. The error is present on the contours that are circular. When smoothing is applied the tool-path will close 50% of the circle and then do some lead-operations on the wrong side of the contour. When I turn off smoothing it generates the tool-path as it should do. Smoothing setting was 0.01mm. To toggle the error the tool-path has to be regenerated upon exiting the settings dialog box.
