2D contour hole leaving material one wall
I asked for help for this in the manufacturing forum. It was suggested that I also report it here.
Solved: 2D contour hole leaving material on wall - Autodesk Community - Fusion 360
I'm creating a basic plate with hole as an electronics panel. I am using 2D contours to create all the holes. A couple of the smaller holes had there original tool path leaving extra material on the walls and not finishing out to the diameter of the hole.
The workaround was to change compensation type to Material then back to In Computer. There is no obvious reason why the original tool path was leaving this material.
Screen capture and F3D file are on the original post.
