Your latest update broke posting to network folders
chjade84
chjade84
Nevermind.
There's no way to delete posts?
See below.
jhackney1972
Just select "Accept Solution" on your original post is the best you can do.
John Hackney, Retired
chjade84
Ok, I thought I figured out what gives, but it turns out to not be the case.  My original problem still persists.  Before the latest update I was saving posts to my machine's shared network folder.  Now, it refuses to save files there so I have to manually copy and paste them from my local drive to the shared folder.  Massively annoying.
bentwookie
I've had to create mapped network drives in File Explorer to get Fusion to save to remote stores. After you do that, the naming goes from something like \\bla\shared to something like Z:\shared.
Just be aware, the other bug that comes and goes is Fusion will wedge up if it ever needs to show a save dialog pointing to a network drive or folder it can't reach. I've lost work a few times while trying to output meshes.
chjade84
It worked for 16+ months the way it is and now, it lo longer does.  I can't think of anything that has changed except the Fusion version.
