Young's modulus definition error
zain_kalim_807
zain_kalim_807
I am trying to run an impact simulation of 2 bodies, made of custom materials. These materials (Tungsten alloy and rolled steel) are non linear. The simulation does not compute however, and when i check the solve details, it shows 4 errors. Here they are in order
- Error : Young's modulus defined on MAT1 1 is 2.7+E11
- Error : Young's modulus defined on MAT1 2 is 2.19E+11
- Error : Solver error
- Error : An error occurred while solving the model
Please provide me with some answers, i will give more information if needed
henderh
Hi @zain_kalim_807,
One possibility for the error could be a values mismatch in the nonlinear material definition. The Young's Modulus value needs to match the slope of the stress-strain curve between points 1 > 2 (which is defined by the Initial Yield Stress value).
If this doesn't resolve the issue, could you attach the dataset?
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
zain_kalim_807
Yes! It worked! Thank you so much, I really appreciate it.
henderh
Awesome news it worked! Thank you very much for the confirmation follow-up.
I've logged F360CXD-11837 to improve our help page for this requirement.
Hugh Henderson
