Yet another cannot save error
beauglehalld
beauglehalld
I  know this has been covered ad nauseam, but I think this is slightly different.
As well as not being able to save designed that saved mere minutes ago, checking linked files and all the other common suggestions, and getting that lovely "saving 0 of 1 design" message, Fusion has taken me one step further and if I attempt to open another file, it tells me I am not in the correct team.  I have, and have only ever been in, one team, my own.
This error can happen mere minutes after a successful save or it may take days.  It can happen with one file open, or with 10 (very annoying).
I know I can exit and clear the cache and/or reinstall, but that never helps with the "right now" of having files that cannot save, and it's is annoying and time-wasting to have to export them all and reimport them (especially if I am in front of a class).
Has anyone worked out the root cause of this sort of error and/or does anyone have a permanent solution?
It's all great when it works, but it works just long enough to breed confidence and then it does this to me... every time!
beauglehalld
And... just to add insult to injury, the export done prior to closing Fusion does not have the latest updates. It seems to be an export of the last saved version... lost lots of work... thanks Autodesk!
