Yellow discoloration Artifacts on ABS render
See design view and the rendered view below.
 - I have changed lighting, and material from ABS to Powder coat etc.
 - Set Render times from quick to super etc
 - I cannot seem to get the odd yellow blobs to go away. Ideas?
 - Thanks for your help. let me know what other details you may need.
 - Really appreciate any clues.
jeff_strater
I am in no way a rendering expert, but it looks as if this may be reflections from the environment.  Try choosing a different Environment in the Render Setup dialog:
or, changing the brightness setting in the main settings tab:
Just a guess, though.  If you share the model, others can take a look.  Thanks.
Jeff Strater
Engineering Director
