XML file error
XML file error
rosch100
Observer Observer
XML file error
rosch100
Observer
Observer
Please help to fix this.
ryan.bales
Autodesk Support
Autodesk Support
Hi @rosch100
What is the problem? Or when does it occur?
Ryan Bales
Fusion 360 Product Support
rosch100
Observer
Observer
When I open Fusion360 and click on I get this error message and no access to data panel.
This XML file does not appear to have any style information associated with it. The document tree is shown below.
NoSuchKey
The specified key does not exist.
public/dashboard/data_view_startup.html
A44322A354704DFA
HggZZByW/knl8c3wsx5mUlqHfTrtO/dwY7zVwTUQLZHbPCKCFzVUsrn2X5qydyp1gZG1OTQMzio=
ryan.bales
Autodesk Support
Autodesk Support
The only thing i can recommend is a clean uninstall and reinstall:https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Ryan Bales
rosch100
Observer
Observer
I do not have admin privileges on my user account. However, I can install programs using the <run as admin> option (with separate EDA login credentials) when rightclicking on an installer file. Is there any way to download the installer file instead of the automated install procedure?
ryan.bales
Autodesk Support
Autodesk Support
The automated installer should be able to run with elevated permissions in the same way.
Ryan Bales
