Wrong "Home View" on Drawing
ingussp
ingussp
I guess i'm found some small issue. On Drawings, when i add drawing view, i can choose "Home View". This "Home" is same as on my primary model. The problem is, when i create animation with different "Home", in Drawing it's anyway show my primary model "Home View". To get different "Home" i have 2 ways. I can change it on my primary model , which are very bad idea, because then changing all Drawing file. 2. way, i can create copy from my primary model and then set up different "Home", but in this case i can't include this model to my first created Drawing file. Hope you understood my english.
Have any solution how i can make different "Home" views on one model, and then add them to my Drawing file?
Thank
jhackney1972
I believe your answer is to create a New Named View which will be the view you want to use in your Animation drawing view.  The Screencast will show the process.
John Hackney, Retired
ingussp
Thanks. That's what i'm need. I didn't know about "Named View" before 🤔
jhackney1972
If my post answers your Forum question, please select the "Accept Solution" icon so others can find the answer to similar questions.
