Wrong post-code for fanuc in G73
ghost24SBH9Z
Message 1 of 12
ghost24SBH9Z
I have a problem.
When i use the cycle chip breaker the post code is not correct becuse don't show me the cycle G73 but all the movements in G0 and G1 to execute the drill cycle.
How i can solve?
Replies (11)
Message 2 of 12
KrupalVala
Hi @ghost24SBH9Z
open your post in any editor and search  case "chip-breaking": Now change below code from
      if ((cycle.accumulatedDepth < cycle.depth) || (P > 0)) {
to
        // cycle.accumulatedDepth is ignored
        if (P > 0) {
save the post and test it carefully.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
Message 3 of 12
ghost24SBH9Z
This is my post now after your advice but anything change
case "chip breaking":
      //(cycle.accumulatedDepth < cycle.depth) ||
      if (P > 0) {
        expandCyclePoint(x, y, z);
      } else {
        writeBlock(
          gRetractModal.format(98), gCycleModal.format(73),
          getCommonCycle(x, y, z, cycle.retract, cycle.clearance),
          "Q" + xyzFormat.format(cycle.incrementalDepth),
          feedOutput.format(F)
Message 4 of 12
KrupalVala
Hi @ghost24SBH9Z ,
Yes. now test it.
Krupal Vala
Message 5 of 12
ghost24SBH9Z
I already tested it but doesn't work
Message 6 of 12
KrupalVala
Given solution should work. please check with  latest fanuc post. Else try with below codes.
      if ((P > 0)) {
        expandCyclePoint(xyz);
      } else {
        writeBlock(
          (properties.type == "A"? "" : gRetractModal.format(98), conditional(properties.type != "A"gAbsIncModal.format(90)), gCycleModal.format(73),
          getCommonCycle(xyzcycle.retract),
          peckOutput.format(cycle.incrementalDepth),
      break;
thanks,
Krupal Vala
Message 7 of 12
ghost24SBH9Z
Post processor engine: 4.5699.0
Configuration path: D:\Programmi_Installati\Utilit� Fusion360\Post-Processor\dmg mori nhx.cps
Security level: 1000
Include paths: D:\Programmi_Installati\Utilit� Fusion360\Post-Processor
Configuration modification date: Sunday, August 16, 2020 6:06:47 PM
Output path: C:\Users\ghost\AppData\Local\Fusion 360 CAM\nc\1.nc
Checksum of intermediate NC data: 5c5eeee05591e9985fd472e5af0a1ab3
Checksum of configuration: 6a0fa0ff5b03704d0be19b37ec6e12a5
Vendor url: http://en.dmgmori.com
Legal: Copyright (C) 2012-2020 by Autodesk, Inc.
Generato da: Fusion 360 CAM 2.0.8809
Warning(D:\Programmi_Installati\Utilit� Fusion360\Post-Processor\dmg mori nhx.cps:1526): reference to undefined property properties.type
Errore: ReferenceError: peckOutput is not defined
Error at line: 1528
Error in operation: 'Foratura8'
Stack dump:
onCyclePoint(-397.5,-37.5,207.5)@D:\Programmi_Installati\Utilit¢ Fusion360\Post-Processor\dmg mori nhx.cps:1527
Failed while processing onCycle() for record 386.
Errore: Failed to execute configuration.
Stop time: Sunday, August 16, 2020 6:06:58 PM
Post processing failed.
Message 8 of 12
KrupalVala
Hi @ghost24SBH9Z ,
please share your post processor file (*.cps).
Krupal Vala
Message 9 of 12
ghost24SBH9Z
There is.
Message 10 of 12
KrupalVala
Hi @ghost24SBH9Z ,
I though you are using Fanuc generic post. No problem. based on your post i have updated the code.
        if ((P > 0)) {
        } else {
          writeBlock(
        break;
Save the post and test it carefully.
Krupal Vala
Message 11 of 12
ghost24SBH9Z
ok great!!
Thank you so much for your help.
Now it work.
Message 12 of 12
KrupalVala
Hi @ghost24SBH9Z ,
Thanks your for your feedback. There was a diff. in cycle name-> chip breaking &  chip-breaking.  That's why first solution did not work.
IF my answer solve your question, could you please click the "Accept Solution" button ? This helps everyone find answers more quickly!
Krupal Vala
