Wrong part name in the BOM
francois_riot7TBHB
francois_riot7TBHB
I am trying to use the BOM tool in fusion, but it keep showing wrong part name.
exemple :
On this picture you can see that the component FAN_Sr20iA_L01 show an other name on the BOM( S300_Ass ) not present in the properties of the component.
Is this normal? And if not how to fix this?
jhackney1972
You will need to attach the assembly in question so the Forum users, and Autodesk, can trouble shoot the issue.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
