Working with an .ipt file
Hi Guys,
I'm getting better with Fusion 360, but there are still a lot of things I need to learn.
I am having trouble with an .ipt file which I understand is manageable in Fusion 360.
I've tried YouTube but no help.
I am trying to just change the TEXT in the file I have enclosed.
Can anyone help me with that?
It would be appreciated.
Guy
dsouzasujay
Hi @Anonymous ,
Created a video to show how we can do an edit cut using text.
Video:https://knowledge.autodesk.com/community/screencast/7745560d-1af2-4018-8d96-10016ac1454a
Let me know if you looking for same or something different.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
HughesTooling
You can just window select the existing text and delete, just make sure you have Select Through enabled.
Mark
Mark Hughes
Owner, Hughes Tooling
g-andresen
1. delete faces
2. create new text in sketch
3. extrude/cut
Screencast
günther
As usual, Guenther is spot on!
Thank you for your quick response and the video said it all.
I am so glad to have a community that is so responsive.
I want to thank the other members who responded as well, you guys are great!
Thank you!
I got it to work, between a couple of the supporters that answered to make it happen.
You guys are the best!
