Window bug
Window bug
friesendrywall
Message 1 of 19
Window bug
friesendrywall
On windows7 x64, see how the tool window always goes out of sight.
Replies (18)
Message 2 of 19
jhackney1972
I am running Fusion 360 on Windows 10 x64 and do not see the same issue.  I would like for you to try something, the next time you open the tool library dialog panel and move it down as you did in your screencast, drag the entire dialog box down a half inch further and also size it a bit smaller using the top edge of the box.
John Hackney, Retired
Message 3 of 19
friesendrywall
That fixes it temporarily, but I have already tried similar before, and something ends up resetting it back to this position.
Message 4 of 19
friesendrywall
I can confirm it comes back.  So far I haven't pinned down what action does the reset.
Perhaps the dev team can review their window remember/placement code for bugs?
Message 5 of 19
friesendrywall
To recreate, open and close the tool window, it opens a bar width higher every time it opens.
Message 6 of 19
friesendrywall
Bump.  This bug is still around.
Message 7 of 19
friesendrywall
This bug also affects other windows.
Right click, edit notes on a CAM operation raises the window one top bar width each time it is opened.
Message 8 of 19
friesendrywall
Keeping this in view.
Message 9 of 19
friesendrywall
Some more, or let me know the email to submit bug reports.
Message 10 of 19
ARTHUR-HM
This bug drives me nuts. Happens every time for me. Both my office pc, home pc, and work laptop.
Message 11 of 19
friesendrywall
Thanks, it drives me nuts as well, thus the effort to keep this closer to the top in this support river.
Message 12 of 19
lichtzeichenanlage
I'm running Fusion 360 on an Notebook with Windows 7 Ultimate. Sometimes on the notebook monitor, sometimes on a tripple monitor setup. Never experienced this bug and just tested it again with no problems. Can't confirm this bug.
Message 13 of 19
friesendrywall
Did you note the part about the window moving up each time you open and
close?
Message 14 of 19
friesendrywall
Another support reminder.
Message 15 of 19
lichtzeichenanlage
@friesendrywall: Not sure if you replied to my post, but here is a screencast that I don't have the problem:
Message 16 of 19
friesendrywall
This bug still exists.
Message 17 of 19
friesendrywall
It also exists in the sub windows that open from the tool library windows.
It doesn't happen with all projects, but once it starts it won't quit.
Message 18 of 19
friesendrywall
Bug still exists in edit notes window.
Message 19 of 19
friesendrywall
Its in the code that remembers window position.  The window position remembering code is obviously offsetting it the amount of the win7 frame top.
