Why wouldn't this work for Flat Pattern?
sprudzs.edmunds
sprudzs.edmunds
Dear all,
I'm trying to get the sheet metal model attached to create a Flat Pattern. It produces some warnings (yellow and, sadly, meaningless to me) and creates a Flat Pattern instance which is empty. Do you have any ideas?
Thank you for your time,
Edmunds
HughesTooling
If you override the 3 corner bend relief radius to 0.5mm it works. See attached file.
Mark Hughes
Owner, Hughes Tooling
TheCADWhisperer
I recommend starting by fully defining Sketch1.
sprudzs.edmunds
Edmunds
ryan.bales
Autodesk Support
Autodesk Support
There is honestly likely a defect here, but to fix this:
  1. Roll back the timeline to the first sheet metal feature
  2. Create the flat pattern
  3. Roll forward the timeline one step
  4. update flat pattern
  5. Repeat 3 & 4
  6. Flat pattern will now generate, albeit still with warnings.
Ryan Bales
Fusion 360 Product Support
sprudzs.edmunds
