Why was compare in the manufacturing simulation removed?
The latest update has made the simulation more frustrating, and did not fix any of the problems I had with it.
First, the compare is an essential tool to me. I can see no rational reason to remove it. Has it just moved to a different menu?
Second, the automatic instock generation seems to conflict with the simulation making impossible to visualize multiple setups on the same part.
When will this things get fixed?
jhackney1972
Is this the Manufacturing Environment "Compare" you are speaking of?
John Hackney, Retired
Negative,
The one I am talking about is simulate, on the actions bar right next to post process. then on colorization you could select compare. Blue is stock, Green is within the tolerance window of model, and red is where it cut into model. you can see it still on the tool tip, but it is no longer in the colorization menu.
So now I see that I have to put the mode to standard, then i get comparison back. Maybee just the default mode got changed, and I got impatient looking throgh the menu.
That also fixed my other problem too.
Thanks for making me dig through the menus to explain it though, I would have cussed at the computer for another week or two before I discoverd it again.
