why is this happening ?
mreynoldsTPVRE
Observer Observer
mreynoldsTPVRE
Observer
Observer
So making the model I'm working on and it's tilted, ??  not sure how, or how to fix it. thank you.
  • Help
TheCADWhisperer
@mreynoldsTPVRE
Did you intend for this to be 3 different bodies at this stage?
with interference between the bodies?
or did you intend to Join?
Is your Sketch3 fully defined?
Did you intend to Cut circles through the part?
HughesTooling
Try resetting the view cube (Reset Front).
Mark Hughes
Owner, Hughes Tooling
mreynoldsTPVRE
Observer
Observer
No, but I need bodies 4 an 5 to be 1 inch when joined to body 3 making thickness in them areas 1.5".
I'm not sure, I learned on SW.
Did you intend to Cut circles through the part? No, I need tap holes .75" and 1.25" deep.
 Thank you.
TheCADWhisperer
CSWP here since 2007.
Apparently you didn’t have a very good instructor - there is no difference between SolidWorks and Fusion 360.
