Why does Fusion Take So Long to Exit?
Anthony_Anz
Message 1 of 13
Anthony_Anz
Not sure when this started happening but it seems that Fusion just takes a really long time to exit.   If I do not have any model open, and I click the X to close Fusion, the fusion window just sits there white for about 10 seconds before the window finally goes away.  What exactly is it doing in those final seconds?  I have no files open, nothing is actively saving/syncing.   Why doesn't it just quit immediately?
Replies (12)
Message 2 of 13
dsouzasujay
Hi @Anthony_Anz ,
Good question, and I agree, it can feel a bit odd when Fusion doesn’t close immediately.
Even if no design is open, Fusion still goes through a short shutdown sequence in the background before exiting. During those few seconds, it may be:
  • Finalizing any background cloud sync or cache updates
  • Closing active services and local processes (Fusion runs multiple components under the hood)
  • Writing logs or telemetry data
  • Releasing GPU and system resources cleanly
The white window you’re seeing is essentially the UI closing before those background tasks finish up.
A couple of things to check:
  • If the delay is consistently around ~10 seconds, that’s generally within expected behavior
  • If it’s getting longer over time, it could be worth checking:
    • Network conditions (cloud sync delays)
    • GPU driver updates
    • Whether Fusion is fully up to date
If you’d like, we can also take a closer look at logs to see if anything specific is slowing down the shutdown on your system.
Let us know if the delay increases or starts impacting usability.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 13
Anthony_Anz
Thank you so much for the detailed reply.  I can totally understand it's cleaning stuff up in the background.  From a users perspective though it looks like a UI hang.  Perhaps a status bar displaying shutdown progress?
Message 4 of 13
dsouzasujay
Hi @Anthony_Anz
Can you please your machine diagnostic log files?
We will investigate the log files to see and understand the launch time.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 13
Anthony_Anz
Hi Sujay, attached are my log files.     Hope it helps.
Message 6 of 13
dsouzasujay
Hi @Anthony_Anz ,
Thank you for sharing the log files.
Development team also request to share the "Report Performance Issue" report for more details.
  1. Start Fusion application
  2. Start CPR recording
  3. Close Fusion
  4. Stop CPR recording after Fusion close complete.
Please send report after this.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 7 of 13
Anthony_Anz
OK. I submitted my performance issue log.  hope it helps.
Message 8 of 13
dsouzasujay
Hi @Anthony_Anz
Could you please share the Performance Report Number or your email?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 9 of 13
Anthony_Anz
If I can find the report number I'll add that too.
Thanks!
@Anthony_Anz - this post is being edited to remove PII.
Message 10 of 13
dsouzasujay
Hi @Anthony_Anz ,
Thank you for sharing the email, i will request our team to fetch the report number from the email.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 11 of 13
Anthony_Anz
Hey, by the way, posting my email address got me a community violation.  I guess keep that in mind in the future when asking people for info.  🙂 probably better to have just asked me for the reference number.
Message 12 of 13
dsouzasujay
Hi @Anthony_Anz
Going forward, I will try to collect personal details through direct messages. For now, I have your email address, and we have logged an internal ticket (FUS-243813) to investigate further.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 13 of 13
sanjana.shankar.goli
Autodesk Support
Autodesk Support
@Anthony_Anz Thank you for logging a performance report. Our team has looked into the report but it looks like there was only 2 seconds of recording for Fusion. Can you please send us another performance report with the same steps mentioned by @dsouzasujay  ?
  3. Close Fusion
We would need Fusion to run for at least 10 to 15s in the recording to get enough information to investigate the issue. Thanks again!
Sanjana Goli
Software QA Engineer
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
