why are these corners cutting this way?
sailhatin
sailhatin
so I created this body in shapr3d as I like to design with the iPad and pencil. tossed this into fusion and then I started to get this real wild corner cut. any idea why this is happening. ive attached the file im working with. thanks in advance for your time.  jonny
TrippyLighting
I am not sue this is the reason for the issue, but that object you designed is two(2) separate solid body, not a single combined one.
sailhatin
thanks for the quick response. ill join the bodies and then see what pops up. thanks a ton, im really new to this and it seems like one of the coolest things ive done in years. from building my cnc machine to learning the software its been awesome.
sailhatin
well...that was the fix right there. I just joined the bodies in shapr and it worked perfectly in fusion. thanks a ton. really really appreciate it.
