The following picture shows four lines and four intersection points.
Next, an ellipse is drawn and connected to three of the intersection points.
If the ellipse is deleted, the three points associated with it are also deleted. There is no warning. The same behavior also occurs when the upper half of the ellipse is erased using trim.
I find the behavior very impractical, especially when I work with trim. If I use a spline instead of an ellipse, I can delete the spline and the points are preserved.
Here is the link to the project: https://a360.co/3lL4fTM
