White square when selecting faces
kschepens
kschepens
When I select a face, I get a large white square that blocks the view.
This is since one of the lasts updates. This worked before.
Is this a bug?
TheCADWhisperer
Don't know if it is related to your issue - but what are the yellow triangles about?
Does Ctrl b (CMD b on mac) return any errors?
What graphics card/driver?
jhackney1972
This is probably a graphic issue.  First of all, make sure your video card drivers are up to date.  Next, go to Preferences and change your choice of Graphic Driver, which require you to restart Fusion 360.  I would chose a driver other than Auto-Select, such as DirectX 9.
John Hackney, Retired
kschepens
Hi jhackney1992,
I changed it to DirectX 11 (was OpenGL) and that did the trick. Strange, because I did not change anything there.
Anyway, thanks for the help! It's working again 🙂
Cheers,
Koen
