Where's the Make menu gone?
autodeskB5RMD
Message 1 of 19
autodeskB5RMD
I just want to send my design to my slicer but the make menu has gone, arghhh!
Replies (18)
Message 2 of 19
julia.paganucci
Autodesk Support
Autodesk Support
Hi @autodeskB5RMD ,
Thanks for posting! The make menu is still here..
Can you try resetting your toolbar? If that doesn't work, please reinstall Fusion 360
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
Message 3 of 19
autodeskB5RMD
Yep, that's what my toolbar looked like up until today, but now I have "Design" workspace instead of "Model" workspace and no Make menu. Trying to reset the toolbars does nothing.
This is what my toolbar looks like
Message 4 of 19
julia.paganucci
Autodesk Support
Autodesk Support
Hi @autodeskB5RMD ,
Thanks for the screenshot! It looks like this is happening because you are have "UI Preview" enabled, which changes the default UI and the toolbars. To change it back, click on your name in the upper right hand corner, click preferences, and uncheck and box next to UI preview on the preview tab.
Julia Paganucci
Message 5 of 19
autodeskB5RMD
Thanks for that. Iknow what happened now. I installed Fusion360 on a new laptop not realising the settings are for the account rather than the machine, so when I checked UI Preview on the laptop, it changed the settings on my desktop machine too.
Thanks for you help
Message 6 of 19
michael55SE4
So there's no Make Menu in the new UI?   What are we doing to do when that becomes the only option?
Message 7 of 19
@michael55SE4 It's the first item in the "Tools" tab, in the "Design" workspace. New UI takes some getting used to, but so far I haven't seen any functionality go missing...
Message 8 of 19
michael55SE4
Thanks!  I appreciate the tip,.
Message 9 of 19
bruceCQJ6G
@julia.paganucci is there an update to this issue?
I have no UI Preview selection in Preview Preferences, and no Make menu.
And Makerbot plugin is running according to F360 add-ins dialog, but doesn't present in the UI as expected (I'm guessing these are all related).
Message 10 of 19
bruceCQJ6G
Sorry, I found it!  This support page helped me understand where everything now is, including Make icon, and the missing Makerbot add-in UI!
Message 11 of 19
I found a menu item under the "File" menu called "3D Print"  it appears to have the same options as the old "Make" menu.
Message 12 of 19
ryan.bales
Autodesk Support
Autodesk Support
Hi @Anonymous the make menu is under tools:
Ryan Bales
Fusion 360 Product Support
Message 13 of 19
nexusfpvnw
Observer
Observer
Same here, thanks for the tip!
Message 14 of 19
The UI option is not in my version
Message 15 of 19
davebYYPCU
But you will have
Tools Menu Tab on the main page.
Message 16 of 19
I did find it. It was in the File menu. all works now. Thanks.
Message 17 of 19
Nice!!! I found the make option!! 100% Thank you!!
Message 18 of 19
mi.silva
Hi
Where is the "tools" tab please!
Message 19 of 19
g-andresen
here > attached (Embedding fails)
günther
