Where can I find all of the Fusion 360 menu icons as images
tom.macpherson-pope
Message 1 of 9
tom.macpherson-pope
I'm writing a workshop on Fusion 360 and it would be useful to have all the menu icons as images to reference when talking about the particular tools; is there anywhere I can download these from?
Tom
Replies (8)
Message 2 of 9
JeromeBriot
These icons are in the "Fusion\UI\FusionUI\Resources" subfolder where Fusion 360 is  installed on your machine.
On Windows, for the lastest version of Fusion 360, the folder is :
C:\Users\<userName>\AppData\Local\Autodesk\webdeploy\production\a0e1972bd3aaf7a114595ea6aa8bdc2a1583062a\Fusion\UI\FusionUI\Resources
On Mac, the corresponding path should be:
/Users/<userName>/Library/Application Support/Autodesk/Webdeploy/production/a0e1972bd3aaf7a114595ea6aa8bdc2a1583062a/Fusion/UI/FusionUI/Resources
The name of the folder "a0e1972bd3aaf7a114595ea6aa8bdc2a1583062a" change after every update of Fusion 360.
Message 3 of 9
tom.macpherson-pope
Thank you Jerome, exactly what I needed.
Message 4 of 9
laroot
Thank You!
I was trying -- without luck -- to identify an icon that popped up when I selected a line and that I'd not seen before. Working through the file that you posted, I learned that the icon identified the line as a projection.
But, WOW, it would be much more convenient if Autodesk posted in their education files a graphic of the icons, their names, and what they indicated.
VERY respectfully,
Larry
Message 5 of 9
OceanHydroAU
What was the icon, and where did it show up?
I'm struggling with a problem of projections "not sticking" when I change parameters - this icon looks like a clue I need!
Message 6 of 9
Hi. I'm not able to find the icons in the new update. Where can I get their images now? Thanks!
Message 7 of 9
OceanHydroAU
Try this on Mac
cd ~/Library/Application\ Support/Autodesk
find . | grep png$
Message 8 of 9
g-andresen
did you notice this  (# 2):
The name of the folder "a0e1972bd3aaf7a114595ea6aa8bdc2a1583062a" change after every update of Fusion 360.  ?
günther
Message 9 of 9
carterstengel
Observer
Observer
Thank you! Found it perfectly.
