when zoom missing line in drawing i see only points
RadoG
Message 1 of 27
RadoG
Replies (26)
Message 2 of 27
HughesTooling
Is your graphics card driver up to date? And does your graphics card meet Fusion's minimum requirements?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 27
RadoG
NVIDIA GeForce RTX3060 Laptop GPU last drivers 12.06.2023
Message 4 of 27
TheCADWhisperer
@RadoG
If you reboot the computer - does the problem persist?
Message 5 of 27
jhackney1972
You also can try a different Graphic Driver listed in your Fusion 360 Preferences.  Fusion 360 must restart between changes.
John Hackney, Retired
Message 6 of 27
RadoG
I have had a problem for 6 months, updating the driver and uninstalling Fusion didn't fix the problem
Message 7 of 27
rhawthorne73UZ5
I am having this same problem with Fusion. For some reason when zooming in straight lines disappear, and curve lines become bold (video 1).
So far this has only happened when I used the generic Fusion format - the templates I've made don't have this issue.
However - in all my prints, when I use the "Sketch" feature in a drawing file, I get the same behavior (video 2).
Our IT group checked out my setup and the requirements and said the video drivers are up to date and the laptop is sufficient to run Fusion.
Is there a way to fix this? Or settings I can try to adjust?
I saw this forum mentioned a similar problem with no fix yet: https://forums.autodesk.com/t5/fusion-support/fusion-360-drawing-zoom-displaying-issues/m-p/12401824
Message 8 of 27
HughesTooling
@ClintBrown3D Any ideas on this?
Mark Hughes
Message 9 of 27
mohammed.aliTDPXK
Hello @rhawthorne73UZ5 ans @RadoG ,
Sorry to hear on the issue you are facing, can you please confirm, we have been trying to reproduce this issue at our end but unfortunately no success,
  • Can you please confirm which OS you are on (Win 11, Win 10 or Mac OS)
  • Can you please check if line weights display is checked in Documents settings? If yes, can you please try to uncheck and try again and see if you see lines or still lines goes missing?
  • Please send us the drawing file for investigation, you can also send a direct message to me if you don't want to share it public.
Md Adam Ali
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
Message 10 of 27
rhawthorne73UZ5
Hello @mohammed.aliTDPXK,
Thank you for looking into this.
  • Operating system is Windows 10 Pro, 64 bit
  • Yes, "Display Line Widths" is checked - see screenshot
  • I will send you a direct message.
Message 11 of 27
mohammed.aliTDPXK
Hello @rhawthorne73UZ5 ,
Received the file, thanks for the information. We have logged this issue as FDWD-18199(internal use). I will check with my team and get back to you soon.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
Message 12 of 27
mohammed.aliTDPXK
Can you please also confirm if you see this issue when you uncheck the link widths?
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
Message 13 of 27
rhawthorne73UZ5
@mohammed.aliTDPXK No, turning off the "display line widths" option has no change in the drawing view.
Message 14 of 27
HughesTooling
Is this on a dual graphics card system? What does Fusion's graphics diagnostics show for what graphic card is being used by Fusion?
Mark Hughes
Message 15 of 27
rhawthorne73UZ5
@HughesTooling
Integrated graphics card: Intel(R) Iris(R) Xe Graphics.
GPU RAM: 128 MB.
Dell XPS Laptop - 12th Gen Intel(R) Core(TM) i7-1250U 1.10 GHz.
I have tried switching the graphics between the three options (OpenGL Core Profile, DirectX 11, and DirectX 9) with no change in performance.
I have not tried uninstalling and reinstalling Fusion yet.
Message 16 of 27
MRWakefield
I made a new post about this yesterday as I hadn't seen this thread. I'm having a very similar issue. I'm on a brand new Dell Precision 7780 with Intel on-board graphics and an NVidia RTX 3500 Ada graphics card running Windows 11. I've tried all of the various graphics driver options within Fusion but it has made no difference to the issue. I have updated the NVidia drivers to the latest version but that has made no difference either. If I turn off 'Display Line Widths' the issue doesn't occur.
This occurs with all drawings that I have tested it with.
If you require any further info just let me know.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 17 of 27
rhawthorne73UZ5
@mohammed.aliTDPXK      I tried opening the file on another computer in our shop that uses Fusion - it had the same problem with viewing the lines when I opened the file, so it does not seem to be limited to my device.
Message 18 of 27
mohammed.aliTDPXK
Thanks for the additional information, I am checking with my team, will get back to you on this.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
Message 19 of 27
mohammed.aliTDPXK
Hello @MRWakefield ,
Can you please mention if you are on extended monitor? We have already reported this issue internally and I am checking with the team on what's happening here.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
Message 20 of 27
MRWakefield
No, just the standard built-in 1920x1080 laptop monitor.
Marcus Wakefield
