When performing a command such as symmetry or extrusion, the white box is not displayed to proceed with the command, please help
u19204215
u19204215
When performing the action of activating a command, the white box is not displayed. For example, in symmetry, the box to select the object and later the axis does not appear, the version I have is 2024, help me
TheCADWhisperer
@u19204215
I do not know what this means.
Can you Attach screenshots of what you see?
Did it used to work on this machine, but now it does not?
Did it never work on this machine?
Are you, or have you been using multiple monitors?
Probably more questions, but let’s start with these.
u19204215
Thanks for answering, it turns out that when I want to carry out commands such as symmetry or divide body, the white box that should appear to continue with the command does not appear. In the case of symmetry, the box that tells me to select the object and then choose the axis of symmetry, for this reason I have not been able to carry out these commands.
carl.j.barker
The first thing to try would be reset layout (ctrl-alt-r).
u19204215
THANK YOU VERY MUCH IT WORKED VERY WELL FOR ME THANK YOU VERY MUCH REALLY HELPED ME NOT TO FAIL MY EXAM BY 20% OF MY AVERAGE, THANK YOU
