when i try to finalise the form i get this "Error: Conversion error for: Body2 The operation failed due to a self-intersecting surface. Try adjusting the values or changing the input geometry."
s10shailert
s10shailert
Community Visitor
Community Visitor
when I try to finalize the form I keep on getting this error message "Error: Conversion error for Body2
I can't see the error in red and I can use the repair tool to repair it
sutherland-
Hi @s10shailert
Your model is self-intersecting. You need to go through the faces and see where the self-intersection occurs.
As of I can see in the model itself, it will be really hard to find it, so my suggestion would be to try modeling the teapot again and baring in mind those steps.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
